Outlook 2010 Outlook not connecting to servers at Comcast.
bugmeso
Just in the last 2 days my Outlook 2010 connects to my Gmail account and downloads the email but does not connect to the server for 2 email accounts at Comcast. Have talked to the techs at comcast and they nothing on their end. The advised to delete the comcast accounts and reinstall them. Did that and even changed passwords, still not go. comcast says it is something on the Outlook end. Any ideas anyone?
bugmeso
I do not recall at this time but it referred to ISP server. Worked with them yesterday and this AM and got no where. Called MS and after along time of say "what did you say" is you get the drift. I believe it comes down to the rundll32 file. Trying and reading on how to replace the file that covers so much. Without messing up and having the OS not working at all. I have a MS Office Pro Plus 2013 CD that has been laying around for 8 months but what I read it is a lot different then 2010.
bugmeso
FINALLY!!, all is good and working fine. Copied the rundll32.exe to 2 places recommended. Run the Office Pro 2010 CD and set it to repair. Rebooted, and the email accounts went right in. :)
C connecting to recent outlook file on new hard drive Using Outlook 2
I iPad not connecting correctly to Outlook.com account Using Outlook.com accounts in Outlook 7
S Connecting to OMA from Outlook ? Using Outlook 1
B Outlook not connecting to my email/server Using Outlook 1
C Connecting to an addin in Outlook 2010 (or not) Outlook VBA and Custom Forms 1
B Outlook 213 keeps crashing. I just found out there are DMP files. How can I tell Why? Using Outlook 0
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 7
@ Outlook Using Outlook 2
