Small vba to kill political email
TedSch
Outlook 2016 64 bit
I am on every political email list asking for money. Even though I unsubscribed, they were still coming in different candidates. There are a few major companies (political SaaS) that swap your name around to the difference candidates even when you are not living in the same state. If you look at the email's HTML source, you'll see ActBlue, Npvan, Sendgrid as the main ones if you are a democrat. There doesn't seem to be a way to make a rule that acts on hidden HTML source test. Below you'Il see the code I assigned to a button on the quick access tool bar. It works. It is easy to expand the array for any newcomers. Let me know if there is a better way. Would there be a way to make this a custom rule that operates when new emails arrive? Thank you Slipstick for being the go-to for Outlook.
Public Function ArrayTest(strToTest As String) As Boolean
Dim strTxtArray() As Variant
Dim k As Integer
strToTest = UCase(strToTest)
strTxtArray() = Array("ACTBLUE", "SENDGRID", "ACTIONNETWORK", "NPGVAN", "ACTIONKIT", "USO.ORG", "AMERICARES.ORG", "SIERRACLUB.ORG")
For k = LBound(strTxtArray) To UBound(strTxtArray)
'Debug.Print strTxtArray(k)
'Debug.Print strToTest
If InStr(strToTest, strTxtArray(k)) > 0 Then
ArrayTest = True
Exit For
ArrayTest = False
Next k
End Function
Public Sub DelPoliticalSpam()
Dim oInboxFolder As MAPIFolder
Dim obj As Object
Dim objExpl As Outlook.Explorer
Dim strBodyHTML As String
Dim strTypeName As String
'On Error Resume Next
Set olApp = Application
Set objExpl = olApp.ActiveExplorer
Set oInboxFolder = ReturnFolder(strInbox1, olFolderInbox)
For Each obj In oInboxFolder.Items
strTypeName = TypeName(obj)
' Debug.Print strTypeName
If strTypeName = "MailItem" Then
strBodyHTML = obj.HTMLBody
If ArrayTest(strBodyHTML) Then
'MsgBox (strBodyHTML)
obj.Delete
Next obj
'return to inbox
objExpl.SelectFolder ReturnFolder(strInbox1, olFolderInbox)
Set obj = Nothing
Set oInboxFolder = Nothing
To run it as a rule - see
This should work -
Public Sub DeleteSpamMessage(Item As Outlook.MailItem)
strBodyHTML = item.HTMLBody
item.Delete
TedSch
Outlook 2016 64 bit
Thanks - I've been a fan of yours for a long time!
If I deleted the object/item in the for loop, I found that the previous version missed deleting about 1/2 because it shortened the collection. So, I added the items to be deleted to a new collection and then used a For to delete items in the new collection. That got them all.
Dim obj As Object
Dim strSubject As String
Dim collItems As New Collection
Debug.Print CStr(k) & ": " & strTypeName
strSubject = obj.Subject
If ArrayTest(strBodyHTML, strSubject) Then
collItems.Add obj
'obj.Delete
Next obj
For Each obj In collItems
obj.Delete
Next obj
'return to inbox
Set obj = Nothing
Set collItems = Nothing
Yeah, I didn't pick up on that when I looked at the macro. When deleting (or moving), you need to count backwards or it will skip every other message - if you have 5 and delete the first, message #2 is the former message #3.
For each works fine if you are flagging, categorizing - just not when moving and deleting.
Get the count then step back -
Dim intCount As Integer
For intCount = oInboxFolder.Items.Count To 1 Step -1
Set obj = oInboxFolder.Items.Item(intCount)
' do whatever
next
A OutLook For Mac 16.46 Comes Up In Small Window When Opening Using Outlook 4
N Outlook 2010 prints in small fonts Using Outlook 1
J Office 365 small business/Outlook 2013 issues Using Outlook.com accounts in Outlook 1
P Outlook 2010 Font on Reply Email is Very Small Ruler Will Not Extend Using Outlook 2
J Microsoft Outlook 2007 Font Size Too Small Using Outlook 1
M Add small calendar to navigation Using Outlook 1
M Font Size Too Small When Replying and Sendig Emails on Outlook 2007 Using Outlook 1
S Creating a Reservation Calendar for small business Using Outlook 1
C My Outlook PST size is about 19GB, how can I seperate it into small size of psts? Using Outlook 3
G Small Businesses Owners being priced out of BCM 2010 BCM (Business Contact Manager) 2
J Outlook opens in a small window Using Outlook 4
G Is Office Small Business 2003 compatible with Windows 7? BCM (Business Contact Manager) 1
V I cannot open my outlook small business 2007 BCM (Business Contact Manager) 1
